Hello all! Good day everyone! I have here a power meter that is kind of strange when it comes to its Modbus parameters (or maybe I am doing it wrong). Its name is CHNT DDSU666 power meter, may I kindly ask for some guidance regarding on Modbus for this instrument. I will attach a manual for this specific meter since it is hard to get one. I am using PAC Control to communicate with this meter and an Opto22 Learning Center with SNAP SCM 485-422 module.
P.S.S Here is a little optoscript that I made to communicate with the instrument, but I am apparently getting a 1.#QNAN. I already set my Modbus parameters to 8n1 and my baud to 9600.
Thank you for the reply! I found the answer while looking at my transmit and receive messages seems to be a wrong function call I can read the instrument now
20H means hexadecimal and would be 32 decimal. You can use chr(0x20) or chr(32), but not chr(20) as that is a different number.
With the modbus kit you would take the address you want to read (2000h) and add 1 to it to get the register number (Silly modbus quirk - your doc starts at 0 and the modbus kit is 1 based so you need to add 1 to whatever is in the docs.) So you would want to read 2001h which in OptoScript would be 0x2001 or 8193. You would use the float subroutine from the modbus kit since your device returns values as a “single precision floating decimal”.
With the kit you would do something like this:
//Setup the parameter table
param[0] = 0; //Serial RTU
param[1] = 1; //slave id
param[2] = 1000; //timeout ms
param[3] = 1; //big endien
//Call the subroutine
O22Modbus03ReadHoldingRegistersAsFloat(SCM1, param, 0x2001, ftResults, 1, status);
//Result in ftResults[0] if status is 0, otherwise lookup the error.
The only unknown is if the floats are stored in “big endian” or “little endian” format. Your documentation doesn’t specify. Most of the time it is big endian. This is a parameter setting in the kit subroutine. If the value you get doesn’t make sense, then change param[3] to 0 and see if the value returned makes sense.
