I have an epic with an ignition edge project where there is no internet connection. What is the procedure for keeping my license through an epic firmware update?
I am leery about using the ‘Unactivate’ button on the licensing screen since there’s no internet.
Below is a good response from the Inductive Automation tech support people, with a link to a video.
I would like to note that I didn’t actually follow the process described because they reset my license so that I could use it again. So there was no need for me to do an unactivation.
FROM IGNITION SUPPORT:
The offline unactivation process for an Edge Device/Gateway is the same process for a standard Ignition Gateway. I have outlined this process below:
Before updating, navigate to the licensing page: Edge Gateway > Config > System > Licensing
Unactivate the applied license from the Edge Gateway by selecting the Trash icon
If the device is offline, an unactivation_message.txt file should generate
Upload the file in the “Unactivate Ignition” section
After uploading, our servers will be notified that the license has been unactivated, thus allowing the license to be activated on the newly updated device
