My setup is with a groovEPIC system connected to a PC via a local subnet. The software is PAC Control with three Charts running; one chart for screen IO, another for communicating to the a device, and a third running a FSM. I access groovView through a chrome browser on the PC. The subnet is also connected to a device that is controlled through its ethernet port on the same subnet.
Problem
Intermittently the groovView applications will lose connectivity to PAC Control program. To get connectivity back I have to restart the system groovManage application.
Seems to me that your user session is getting invalidated. You should be signed out and returned to the sign in screen, but that’s not happening. Did you set a session time out in the account that’s signed into groov View? If you increase the session time out, does the problem occur later?
