I have four 110vac switched inputs from multiple power phases to work with.
In essence I need a simple 4 input OR GATE controlled by the above mentioned inputs with a SPDT contact as an output which will be switching a low voltage DC control signal.
I will take a crack of this one (come on lurkers, I know you are out there, speak up!!).
You don’t mention it, but I assume you don’t any any Opto involved in this requirement?
If so, let me know because it will change things a bit based on what inputs you have etc.
In a nut shell, if any of the 4 inputs have power, the coil to the SPDT relay will have power.
If all 4 inputs drop out, power to that relay will stop and the relay will drop.
Usual disclaimer, I might have missed something in your description and so it may not work like you intended.
Also, since mains voltages are involved, you probably should not build it, I’m not qualified to design mains voltage circuits. (Note the lack of a fuse for starters!).
