I had version 5.30.0 already installed in my Epic when I updated the firmware, but was able to install it in a Rio with that firmware version by calling out 5.30.0 instead of just 5
Thanks @JCampbell can confirm that works on an EPIC running 3.6.0
@ddonaldson that should get you up and running.
I will edit my post a few up from this.
Just putting the 5 in worked a few versions back.
@Beno and @JCampbell, Thank you for your help, version 5.30 worked.
@Beno and @JCampbell, Thank you for your time assisting us. Version 5.30.0 worked for me either together with the RIO GRV R7 MM2001
System Version 3.6.0-b.44
NodeRED version 3.1.7
Node.js.version v14.20.0
Wow - I tried to just use 5 and it failed. But using 5.30.0 it worked!
Thanks!
