I have finally found a method for passing tags from Node-RED to Ignition Edge to use in Ignition Designer, but it requires storing values as Context Data in Node-RED then calling these values in the Address Space of an OPC-UA server node (node-red-contrib-opcua-server).
However, I will eventually need to pass a much higher volume of data and I’m wondering if using this method will be an issue if there is a limit to how many values I can store as Context Data.
