Hi, I am confuse.
I know for certain that when I set Trend gadget to be interactive.
The chart automatically will show Adjustable Window Date Range in the bottom.
I want to clarify why date range bar in the bottom does not appear?
Hi, I am confuse.
If the trend’s period + update rate is short enough that there will be fewer than 600 points, we render it as a classic trend. There’s little enough data that we can render the whole thing at once and you don’t need to zoom or pan to see the actual recorded points.
Hi Jonathan,
Its been >24 hours, still no date range at the bottom.
What seems to be the problem?
Thanks.
You’ve configured your trend to span 1 minute, with 1 second updates. That’s only 60 data points total: there’s no reason to display the interactive features with that small a data set. We don’t show them unless your trend is configured to show more than 600 data points.
