How to set up MMP Addresses to report as MQTT SparkPlug
I am trying to set up MMP scratchpad memory addresses to report as part of my SparkPlug payload but cannot find anywhere how to do it.
I am using the GroovManage MQTT SparkPlug setup and I can publish values from the I/O Channels but not MMP values
Did you go to IO Services and make the scratchpad area public?
I did. I set up a start index of 0 and length of 4 for both the 32-bit integer and float scratch pads
Just to be sure, you are changing the values? They are publish on change only, if the values stay static they won’t publish again unless there’s a full rebirth.
