How Can groov Get Excel or SQL Server Data?
#1
Is there a way for a groov box to obtain and use data from an Excel spreadsheet or a SQL Server (or MS Access) table?
#2
Yes. Using KepserverEX you can connect to an SQL server and do a select statement and have the data returned to groov.
I have not done it to an Excel spreadsheet, but don’t think that it would un-doable. I’m not very experienced with Excel, but from a high level, KepserverEX should be able to get data in and out… It seems pretty flexible in its connection options.
#3
Hi Ben,
Thanks for the reply. Which groov box would be required for this, a Groov-AR1 or a Groov-AR1-SNAP?
This would help solve our next update we are planning; a groov box would display both SCADA (PAC controllers) data and lab data (in Excel and SQL) on an LED TV for the Operators use.
#4
OK, thanks.
