Does Opto have or can someone point me toward hardware to read as an analog input up to 600 VAC? I’m configuring a groov EPIC and those modules only go up to 300 VAC. So do the PAC modules.
You will need to use a voltage step down transformer and scale the EPIC input to suit.
We sell such a transformer setup for the EMU, you will need to evaluate if its what you need or if you want to go with another external transformer.
Thanks, I’ll check it out.
I’ve done this with a standard AC transformer. You will want to calibrate the secondary voltage since the output of an unloaded transformer doesn’t correspond perfectly with the winding ratio.
