I am experiencing a counting issue with the above mentioned module. I have contacted support but the reply was not satisfactory.
I am using the above mentioned module to count pulses from a flow meter counter. The unit is rated for 12VDC.
Please watch this video to see what I am experiencing: https://photos.app.goo.gl/6eqEqkJSbaxjsj9JA
The module STATE is reading each pulse correctly but the counter is not functioning as it should. The way I understand it is that each STATE ON should provide 1 count. You will notice the counter jumping a great deal more than the ON/OFF state of the module.
I am using a Bestobel counter that works perfectly in sync with the module STATE when ON and gives the exact same counts. However the module counter is jumping in counts between STATE ON reads.
The module firmware and EPIC firmware are all up to date.
