Hi, from reading the documentation there is mention of Ethernet/IP. It seems its use case is for using Groov IO with an AB PLC.
I am looking to use Ethernet/IP IO with the Groov as the PLC.
In AB world I would either add an AOP or use a Generic Ethernet Module to add the IO to the project.
Can this be done with Groov?
Specifically, I am adding an SMC EX260 pneumatic manifold. There is no AOP, in AB I had this working via Generic Ethernet Module.
