Just a doubt, Currently i have a trusted network on eth0 and interent on eth1. Will I able to access groov view from eth1? Using dns and access it? Or i need to allow firewall to access the groov view?
groov View uses port 443 (the default https port).
Unless you have changed this first firewall rule, you will be able to access it via any interface.
This is the default out of box / fresh from the factory setting (but I know you guys have been making a lot of fast changes).
Got it. Thank you Ben
