What is the best way to see I/O points on a Groov RIO that is on the same network as and EPIC. I would like to use the EPIC as my main clearing house for taking action on I/O points.
Thank You
Thank You
Welcome to the forums! Are you using PAC Control or CODESYS on the EPIC? With both control options you will be able to configure the EPIC to use the RIO’s IO points.
I would plan on using CODESYS
Actually looks like the PAC controller is on. Is there a procedure to access I/O on the Rio
Thanks for the additional information. I’ll provide some resources to get you pointed in the right direction.
I recommend taking a look at our free online training. Specifically the Pac Control topic. Under Creating and Configuring a Strategy you will find a section that walks you through configuring an I/O unit.
Additional resources you may find helpful are:
PAC Control User’s Guide
groov RIO Universal I/O User’s Guide
groov EPIC User’s Guide
