Greetings fantastic forum folk.
We have just released new firmware for your groov RIO MM1, MM2 and EMU.
New Features
- Add native OPC UA server for local I/O and Scratch Pad.
- Add port redirection from VPN or Wifi to Ethernet (To be clear, RIO is still a two port Ethernet switch).
- Add SNMP support
- MMP Scratchpad support for MQTT and OPC UA
- Add support to allow MQTT strings to be published to one broker and SparkpugB to another.
- Updated CA root certificates.
- Update the Java JDK to version 8.0.332
- Rename MQTT menu to âData Servicesâ
- Node-RED bumped to version 2.2.2 (See Terryâs blog about whatâs new).
- Add option to download all status and configuration files in one download
- For the RIO-MM2, Ignition and module version updates.
- For the RIO-MM2, increase Ignition RAM to 512 mb
- Improved certificate information on groov Manage page
- Add more component information to the About Page
Bug Fixes
- KB89890 - User repeatedly prompted to change password
- KB90083 - groov RIO: 0-400k ohm channel type may report quality code 6 for zero ohm input
- KB90206 - MQTT may not scan all public tags after watchdog changes for digital output channels
- KB90223 - When discrete groov module is not detected, quality code reports 0 instead of 30
- KB90315 - Some security certificates are not uploaded
- KB90217 - Static Routes page incorrectly uses the term âNext Hopâ
- KB90221 - Static Route remains in effect after deletion
- KB90328 - GRV-R7-I1VAPM-3: energy accumulation channels report 3x the expected value
Lastly due to the global supply chain issues we sometimes have to change the internal hardware of the RIO family. Fit, form and function is exactly the same, the different hardware simply has a minimum firmware version it can run (the new firmware has new drivers in it). This will be shown on the About page if needed.
Links to the new 3.4.0 firmware for RIO-MM1, RIO-MM2 and RIO-EMU
