I’ve got a groov AR1 with Node-RED flows collecting data from a variety of devices. I’d like to setup a process by which a user would log into a page on the groov to enter specific data which would then be logged to a database via Node-RED.
My question is can Node-RED also collect the name or ID of the user that logged into the page? It would be useful to include that along with the entered data.
I would like to revisit this thread (7 years later).
Node Red in general has the ability to log Audit events. All you have to do is enable audit logging in the settings.js file. Problem is that I have not found a way to access this setting from groov Manage. Any suggestions / updates.
Thanks!
If you enable shell access on your EPIC or RIO, the settings file is available at /usr/share/nxtio/services/node-red/settings.js.
If you enable audit logging, the log won’t have users attached to it: we don’t use Node-RED’s built-in authentication, so it has no idea who’s doing what.
