I have a Groov Epic system that was setup and working fine. I connected it to another computer and now I am getting the following error message when trying to debug a strategy:
“ERROR: Ethernet socket error:Socket is not connected.” Code: -10057.
“Socket is not connected”, means PAC Control doesn’t see the EPIC on the network (IP address could be wrong, etc.) You would get the same message if the EPIC was not plugged in at all.
You are looking at some sort of network issue.
Most likely the firewall on the new computer is set up differently than the old original computer.
The bottom line is that if your network is sound, the computer is blocking access to the controller port 22001 and so you get the socket error.
