I am having issues with the data sync portion of the Ignition Edge on the Opto22 groov epic. For some reason after deleting the database on the master Ignition gateway side, and then reconnecting the system to a new database, the data sync (store & forward) system is broken. I tried resetting the sync id, but it has stayed frozen at 0 since the reset. Is there anything I can do on the opto side to try to fix the issue?
Our firmware updates are monolithic, you cannot upgrade just the Ignition Edge instance on the groov EPIC. We are working on a new firmware release that will update Ignition Edge on the EPIC to 8.1.4X
