I would like some help getting started. I will be using PAC Control Professional. The goal is to turn on and off a motor (clockwise and also counter-clockwise) to move a small piece of equipment up and down. The hardware will be a linear actuator non-capacitive stepper motor, a planetary gear DC motor, and a microswitch used to detect end of travel.
I am trying to investigate what functions and commands I would use to perform the actions of turning on, off, speed, distance, etc. Also, if there are any existing examples related to what I need, I would be appreciative of those links.
As far as code goes, just break it down like you do with your other projects, draw it out as a flow diagram and the PAC Control code will be very close.
