Gateway Connection issue
Hello all. Hoping someone here is able to lend some insight. Have a epic PR2, and using codesys to make the program. When trying to connect to it for the first time to upload the program, codesys will see the epic on the scanning screen. It will then tell me to set up the user management, and use the next screen to set the username and password. After that screen, it says no device is responding. I know the epic and the pc that has codesys installed on can talk (they can both ping each other), and the settings in both are identical to a separate setup (another piece of equipment on a self contained network with and epic and pc running codesys). Not sure what to check.
Rolled the firmware version to an older one release in August 25 and it worked.
