Here’s a quick little flow that uses a shell command to grab the temperature directly from a groov EPIC-PR1 processor. Note that you do not need shell access for this to work, the command does not require root access so Node-RED can execute it without any special permissions!
Also note that the number comes back as a string in milli-Celsius units – but the “convert” function block takes care of that by parsing the string to be a float and dividing by 1,000 to change the output to be decimal value in standard °C. This way you can easily graph it or display it in a gadget.
Here’s the text to import the flow and try it for yourself:
[{"id":"1d8921e9.b5dd4e","type":"inject","z":"e02f10b4.235de","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":1220,"wires":[["ca904b32.a11178"]]},{"id":"ca904b32.a11178","type":"exec","z":"e02f10b4.235de","command":"cat /sys/devices/virtual/thermal/thermal_zone0/temp","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"get temp","x":340,"y":1220,"wires":[["455f6901.a1b438"],[],[]]},{"id":"455f6901.a1b438","type":"function","z":"e02f10b4.235de","name":"convert","func":"// Value returned is a string in milli-Celsius,\n// so convert string->float, and divide by 1,000 to get standard degrees C:\nreturn { payload : parseFloat(msg.payload)/1000 }","outputs":1,"noerr":0,"x":500,"y":1220,"wires":[["a02ca7a2.ccfb98"]]},{"id":"a02ca7a2.ccfb98","type":"debug","z":"e02f10b4.235de","name":"temp (deg C)","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":670,"y":1220,"wires":[]}]
Happy coding!
