Fanuc R30iB Ethernet/IP using Codesys
Hello,
Attached is a Codesys file that I made for the communication settings between a Fanuc R30iB Controller and a Opto 22 Groov Epic controller running on codesys. On the Fanuc side you will have to set up a Ethernet Adapter using 4 words, Set IP address on the same network, and the configure the I/O. You then should be good to go!
Hope this helps!
Fanuc Codesys Comm Settings.zip (600.3 KB)
Wow, great first post! Welcome to the forums with a big splash!
Thanks so much for putting the work in and for posting it for others to learn from!
Many CNC menchance use FANUC Controller.
FANUC provided a FOCAS Library for LINUX System.
EPIC is also a LINUX system, but unfortunate the support of OPTO 22 said this FOCAS can’t be installed into EPIC. We don’t know why???
