EPIC OPC Server integer variable as boolean not working
I’m having problems with using the “As Boolean” in the public access for PAC Control integers not reporting the correct value in the OPC Server. Bit seems to be working (so far).
Config:
Value in PAC Control debug:
Ignition Tag Browser (just dragged the values from the + devices list):
EPIC firmware 3.5.1-b.85
PAC Control Basic 10.5
I do seem to recall this in conversation with with either @greichert or @bensonh
Hopefully either of them can recall the details…
Sorry for the delay…
It was suggested to restart the data service. This should cause a re-sync with the tags.
If that does not clear it up, then please open a ticket with support.
I switched them all to bit types and it is working fine that way.
