We have had this request from a couple of customers now. Ability to access the Enable/Disable and IVAL State Fields in order to override faulty inputs and override logic outputs from EPIC Groov Manage I/O point configuration front panel, or from configured object in a groov view display screen. (Probably more flexibility)
At present you have to go and find the project, load up PAC Control under Microsoft Windows, connect to the controller and go into debug mode or start writing your own control chart to access the instructions Disable Communication to Point and Enable Communication to Point on a point by point basis
