Hello,
There is a “prompted data” section in dynamic attribute send value (Float) dialog box (PAC display configurator professional ) that let’s you set minimum and maximum value the entered data should be in. Is there a way to dynamically change/control the minimum/maximum value from PAC strategy.
For e.g. in PAC strategy IF variable 1 is true, THEN minimum value is 15 ELSE minimum value is 5.
If it’s not possible, only other alternative I can think of is two use separate dialog boxes with different minimum value set.
For e.g. in PAC strategy IF variable 1 is true, THEN dialog box 1 is visible with minimum value of 15 ELSE dialog box 2 would be visible with minimum value of 5.
Any pointers in the right direction will be highly appreciated!
P.S :
We are using-
PAC display configurator professional R9.6g
PAC control professional R9.6e
