DNP3 communication using Codesys
Hi, has anyone ever used DNP3 in CODESYS? I have been assigned to ensure that the EPIC can communicate with another PLC using DNP3. I would appreciate it if someone could guide me with a simple explanation. Thank you.
Codesys has released a DNP 3 module, but not sure if anyone has tested it yet on groov EPIC. You can download it and test it in 2h trial on you groov EPIC.
Codesys DNP 3
CODESYS DNP3 SL
CODESYS DNP 3 Datasheet
@mohdshahs001 did you ever move further on this? I’m about to run a similar test and am interested to know if you ran into any issues.
I spoke with our Codesys support contact, and the DNP3 stack is a runtime component that needs to be built into the runtime.
Unfortunately it does not work with our current runtime. I will add this to our Product Feature Request system.
