Updating hardware in a project from a B100 to a E1 brain and have one G4IDC5 using the “Period” feature in the point definition with the B100, but that feature isn’t available defining a point with the E1. Am I missing something or is that feature not available with the newer brain?
I don’t have one in my office to set up and test, but I am pretty sure that since you are using PAC Control, you don’t ‘have’ to use MMP commands. Use the PAC Control commands, and it will get the pulse duration as usual.
Did some reading.
Looks like the plan was to have it a straight swap. So all the serial commands are as expected (period etc).
However, when migrating from serial to Ethernet, some things changed.
If I have time, I will look into the ModbusTCP options.
