We are in the process of moving our strategies into codesys. Some of our digital intputs (IDCI-12 module) currently use the on-time totalizer feature. When I try to define it in codesys, all I can find is the counter features. Is there a way to utilize the other features?
Yes, currently Codesys does not support the smart features outside of counter. You would need to create this as a function in Codesys. There is a Flow Meter Function available in the OSCAT Library which is included with the Opto 22 Library Package. The function is open source, so you can modify it to fit in your application.
