Thank you for sharing the view from programmability flexibility is concerned, in RPI we have all the access to the webserver and the HMI. Now, do we have this all accessibility of all hardware of EPIC Grove?
Also please share your comments on the IEC 61850 C program library!
groov EPIC uses groov View as it main HMI. You can also use PAC Display to build HMI screens.
With shell access, you may explore other web server options, but we do not support them.
is there any way we can edit webserver as per our customization and also to use variables of our C code to present on the HMI or Webserver. for that we usually use concept of shared memory!
I am perhaps miss understanding, but there is nothing special about the EPIC REST interface… That’s the whole point of REST is its very standardized across devices.
You should be able to use any C RESTful library to make the call.
