Hi, the project I’m handling is an old project, which use visual basic 6.0 to write the value from Opto Display into CSV File. When I try to save the data into CSV file an error message pop out says “Time out! No Response.”. Did anyone know why and its solution?
What commands (button clicks) do you use to save the CSV from PAC Display?
Do you use the historical data log?
How large are the CSV files? (In kbytes)
This is the command in VB6.0 to retrieve data from PAC. I think this is the problem ( I had tried many times on this to retrieve data but still didn’t success. Can you help me to take a look on this?)
