Convert Integer 32 to Timestamp String
Hi All,
Here’s another one that comes up often enough AND, I thought I’d point out why you might consider upgrading to 9.1 (if you haven’t already). It includes the GetDateTime command, used in the example below to create a date/time stamp. Here’s an excerpt from the 9.1 PAC Control help:
Get Date & Time
Function: To read the date and time from a control engine’s real-time clock/calendar atomically (in a single transaction) and put each element an integer table.
Typical Use: This command assures that the date and time are retrieved on the same date.
Details: Reading the date and time separately could result in the following situation:
At 11:59:59 PM, a system operator reads the date—for example, April 1, 2011. Next, the operator reads the time., which now reads 00:00:02. The operator then stores the date and time, which reads as April 1, 2011 at 00:00:02. However, the actual date is now April 2, so the timestamp is a complete day behind. This error can also occur if you read the time first; reading atomically (in a single transaction) ensures you get a snapshot of the exact date and time you asked for.
Here’s some sample code to build a timestamp that looks something like this: “2012-01-24 16:45:22”
  // Construct the timestamp, should look something like: "2012-01-24 16:45:22"
  sTimestamp = "";
  // Get the year/month/day in one transaction (so we avoid any problems w/values
  // rolling over between individual reads)
  // For the GetDateTime command: 0 = month, 1 = day of month, 2 = year,
  // 3 = day of week, 4 = hours, 5 = minutes, 6 = seconds,
  // 7 = milliseconds (unused)
  // This command requires 9.1 or newer PAC Control and PAC firmware:
  nStatus = GetDateTime(ntTimeTable);
  // Year
  NumberToString(ntTimeTable[2], sTemp);
  while (GetStringLength(sTemp) < 4) sTemp = "0" + sTemp; wend // Pad with 0s
  sTimestamp = sTemp;
  // Month
  NumberToString(ntTimeTable[0], sTemp);
  while (GetStringLength(sTemp) < 2) sTemp = "0" + sTemp; wend // Pad with 0s
  sTimestamp += "-";
  sTimestamp += sTemp;
  // Date
  NumberToString(ntTimeTable[1], sTemp);
  sTimestamp += "-";
  sTimestamp += " "; // put a space after the date, before the time
  // Hour
  NumberToString(ntTimeTable[4], sTemp);
  // Minute
  NumberToString(ntTimeTable[5], sTemp);
  sTimestamp += ":";
  // Second
  NumberToString(ntTimeTable[6], sTemp);
  sTimestamp += ":";
I’ve attached a PAC Control 9.1 Basic subroutine too, in case anyone would like to add the “DateTimeToString” command into their 9.1-or-newer strategy.
-OptoMary
DateTimeToString.zip (1.56 KB)
