I’ve been experimenting with this new SDK (R1.0.0.0) to see if I would be able to use it on future projects and found that I cannot start or stop charts through the WriteChartStatus method.
Here is some c# test code with the WriteChartStatus command:
using Opto22.Controller;
using System;
namespace TagIOConsole
class Program
static String sControllerIpAddress = "127.0.0.1";
static Int32 i32ControllerPort = 22001;
static Int32 i32InitialTimeoutMs = 1000;
static void Main(string[] args)
Controller controller = new Controller();
Controller.ErrorResponse eMethodResponse;
eMethodResponse = controller.OpenSession(sControllerIpAddress, i32ControllerPort, i32InitialTimeoutMs);
if (eMethodResponse != Controller.ErrorResponse.Success)
Console.WriteLine("OpenSession() Failed");
Console.ReadLine();
return;
float fTest;
eMethodResponse = controller.Read32BitFloatVariable("f32", false, out fTest);
Console.WriteLine("Read f32 returned {0}.", eMethodResponse);
Console.WriteLine("Float is: {0}", fTest);
//The following line fails with a CommunicationFault
eMethodResponse = controller.WriteChartStatus("Test", Controller.Item.eItemTypes.suspendchart);
Console.WriteLine("WriteChartStatus() Failed");
controller.CloseSession();
controller.Dispose();
Console.ReadLine();
Second, why is there no ReadChartStatus?
To get the chart status I am doing this:
string sChartName = "Test";
Opto22.Controller.Controller.Item[] items = new Controller.Item[1];
Opto22.Controller.Controller.Item chart = new Controller.Item();
items[0] = chart;
chart.SetRead(sChartName, Controller.Item.eItemTypes.chart);
eMethodResponse = controller.ReadGroupItems(items, 0, 1);
Console.WriteLine("RegdGroupItems() Failed");
else
Controller.eChartStatus status;
if (chart.GetData(out status))
if (status == Controller.eChartStatus.Running)
Console.WriteLine("{0} is: {1}", sChartName, "Running");
else
Console.WriteLine("{0} is: {1}", sChartName, "Not Running");
else
Console.WriteLine("Unable to get Chart Status");
Can this be better encapsulated in the API?
