My project need to read temperature from CQM1H (Omron PLC) and visualize with groov View on EPIC.
As customer requested to log the data as excel as well.
I wondered how to communicate to CQM1H from EPIC via ETH0.
My choices on this project are NodeRed, PAC Control or Codesys and groov View
Have you considered using Ignition Edge? They have an Omron driver - Omron FINS Driver - Ignition User Manual 8.0 - Ignition Documentation. However, if you are sticking with Node-Red, PAC Control, Codesys, or groov View, you might look to see if that Omron device supports Modbus/TCP?
My previous reply was incorrect. I use my weekend to study more on Omron CQM1H. I will correct my design a bit. I think I will need the small device below to complete my project.
I would have to do a lot more reading about your Omron before I could answer that and I’m sorry, but I just don’t have the time to dig into that PLC protocol.
I was just pointing out all that Node-RED had to offer, not that any of them would ‘just work’ with your device.
I saw your protocol converter post show up and wondered about its cost and availability.
Modbus is a no-brainer for the output, but yeah, be nice if the hardware converter was not necessary.
I can take a quick google and try and find the manual for your Omron and see if anything jumps out at me, but as I said, Im sorry I just cant spend a ton of time looking into that specific model.
Honestly (not really sure), I don’t think this unit got an Ethernet port but anyway today I’m on site so, I will double check again. Customer interest in to implement first 2 trial of EPICs (portable and one permanent install.
With a great advise from my Opto22’s friend in the past then I try to look back at a device from Welcome to Weintek.com and I think this is very useful for me for now or even as well as future integration.
So we know you do not have that option open to you.
We still don’t know if there is an Ethernet port under the cover above the RS-232 port shown in the photo.
I don’t think it matters as I did not see any mention to Ethernet in this manual:
Other than the ‘Serial Communications Board’ I don’t see any way for any application to really talk with this PLC other than the PC programming application.
