I’m working through Opto22’s CODESYS guide. It automatically has me choose the Ethernet adapter as the communication interface. However, my Groov and the machine I’m developing the CODESYS program on are networked via WLAN and not by ethernet. Following the instructions literally leads to no devices being found on the network scan. Is it possible to reconfigure this to connect to the Groov via WLAN?
The options there are to scan network(used for any DHCP network connectivity). If you are using static PIs, then you would need to type the IP address in the device dropdown.
One thing to keep in mind, specifically when using wifi, is to verify that you have the firewall rules set to allow access to the device over the specified NIC.
