Has anyone tried access to the USB Serial ports on the Epic from CodeSys? What port numbers would they be?
I have a 4 channel Serial IO Module plugged into the 1st slot and working fine, but have no other available slots for a 5th and 6th serial port, which I need.
Here is a screen shot from Epic groovManage with 1 serial USB adapter plugged in. All 5 ports are listed as Devices, but only 4 as CodeSys ports.
