Is there a way to change the name of charts?
Yes! All but the Powerup chart can be renamed. Just open the chart in question, click on it so it’s in “focus,” then go to (in PAC Control config mode): Chart > Rename.
I have tried this but when i am in PAC Control Basic in config mod Chart>rename is grayed out. Any suggestions
Welcome to the Opto 22 forums!
Try this. Double click on the chart name in the strategy tree, this will both open it and select it.
Then from the top menu you should find the ‘rename’ option will no longer be grayed out.
Thanks that solved it
Thanks for popping back and letting us know.
Cheers.
