I succeeded in getting the View DataStore value from Node-RED with http request node + RESTAPI.
But I failed to get the View DataStore value from PAC Control with httpGet + RESTAPI.
Are you using https?
Some help here; Getting Started with the REST APIs for groov EPIC | Opto 22 Developer
EDIT Several hours latter… Yes, I see you have set the security int to be non-zero and you are using port 443, so https it is…
Let me dig into it a bit…
Yeah, I can get DataStore value from Node-RED with same request URL
Sorry to take so long to get back to you on this… Turned out to be a really complicated bug.
More details to come, but there should be a fix from EPIC firmware 3.1.0.
I’m glad there was progress.
I will wait for the release of Ver3.1.0
