I’m trying to develop communications for tag read/writes using Ignition’s OPC-UA
Has anyone worked on this before?
Hello bigschottkyd,
Welcome to the OptoForums! I’m guessing you’re using groov here (yes?) so I’ve moved this to the “groov” forum.
Have a look at this doc which shows some key settings you might need to check.
I hope that helps!
