Add device user codesys
I have an EPIC-PR1, the last firmware, codesys 3.5 SP21 (32bits), i scan the network, select the controller but no appears de warning message about the user management gos directly to the Device User Logon… any body knows how i can add a device user?
thanks a lot
Hello, Codesys will go directly to the log on popup after a user has been assigned. If you don’t remember the username and password you can reset it by following one of the steps from this post: Codesy device user pasword - #4 by greichert
Hi Justin
Thanks for your answer
i reset the controller, upgrade the firmware..but the same
Rodrigo
When you reset the controller did you hold down the reset button behind the door of the Epic for about 10 seconds until the status light started alternating green and red? That will perform a full factory reset so make sure you retrieve any licenses or programs you have installed
yes, and the firware charged was an older
i looking for var/opt/codesys and i dont have the directory
only this
drwxr-xr-x 1 root root 0 Mar 9 2018 backups
drwxr-xr-x 1 root root 0 Dec 9 16:30 cache
drwxr-xr-x 1 root root 0 Mar 9 2018 db
drwxr-xr-x 1 root root 0 Dec 11 13:00 lib
drwxr-xr-x 1 root root 0 Mar 9 2018 local
lrwxrwxrwx 1 root root 11 Mar 9 2018 lock → ../run/lock
drwxr-xr-x 1 root root 0 Dec 11 00:00 log
lrwxrwxrwx 1 root root 6 Mar 9 2018 run → ../run
drwxr-xr-x 1 root root 0 Mar 9 2018 spool
lrwxrwxrwx 1 root root 12 Mar 9 2018 tmp → volatile/tmp
-rw-r–r-- 1 root root 0 Dec 10 16:01 .updated
drwxrwxrwt 4 root root 80 Dec 10 16:02 volatile
drwxr-xr-x 1 root root 0 Mar 9 2018 www
i got it….is in /home/codesys … the you must restart the codesys service in EPIC…and works… thanks a lot
