I opened and registered a new AR1 today. When I try and access Node Red I get this error:
Unexpected token in JSON at position 0
404
SyntaxError: Unexpected token in JSON at position 0
at Object.parse (native)
at /usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/session-file-store/lib/session-file-helpers.js:148:25
at /usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/graceful-fs/graceful-fs.js:78:16
at tryToString (fs.js:455:3)
at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:442:12)
Cannot create property ‘status’ on boolean 'true’
TypeError: Cannot create property ‘status’ on boolean 'true’
at expressApp.use (/usr/local/lib/node_modules/@opto22/src/server/ServerApp.ts:204:27)
at Layer.handle_error (/usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/index.js:310:13)
at /usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/index.js:330:12)
at next (/usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/index.js:271:10)
at Layer.handle_error (/usr/local/lib/node_modules/@opto22/node-appliance-ui/node_modules/express/lib/router/layer.js:67:12)
