If I’m coming back to a project after some time away, is there any way to show which true type fonts have been used? If you select an item and use the “Font” command, then select “TrueType…”, it pops up the selection box, no problem.
But nothing is selected. So even if you just want to change the font size, you have to already know what font was used when the control was created.
Same problem if you need to create new text matching the old text - there doesn’t seem to be any way to know what the old font was unless you wrote it down.
Am I missing something?
