Install serialport@0.14.1 on RIO
Looks like you are trying to install it from the command line.
Also looks like you are trying to install it as root, which is why you are getting a permissions issue.
We recommend that you install the version of any nodes you want via the pallet manager.
If you really want to install via command line, you need to be the user ‘dev’, not root.
sudo su dev
