Thank you for the prompt response! Thank you for the advice on restarting the module as it is easier that going into each tag. It appears on powerup of the Groov it starts the autorun of the PAC strategy before starting the Ignition Edge server so that the tags to populate correctly on powerup. Is this something that I can count on happening consistently?
