I have not beat on EPIC with .NET as much as RIO, but I can tell you that the Linux build in EPIC is a little older that RIO since it was released first.
I seem to recall having issues with 6.0, so if you can, try 5.x
I will try 5.x. I donāt get why 3.1 quit working. But we just keep at it here. The Opto22 folks may need to consider updating the Epic distribution. If I can install GDB we might be able to see what is breaking. I do a lot of Open Software development on the side so I completely understand how software can break. I broke gcc all by myself at least twice in my life. LOL (as the frog would say REVERT REVERT)
We are not simply āmay need to considerā it⦠its a major part of our engineers daily work⦠So yeah we hear you and also feel the pain⦠Its a little over due we know, the supply chain and keeping products shipping is also a big part of their daily workload.
I completely understand Beno. The supply chain issues are getting all of us. Taiwan got put on the sensitive countries list and we canāt buy stuff made there unless the base company is in the US, like Dell. Its nuts. Just today I find out I have to redesign something because of this issue.
Regardless I will let you know what I discover here.
Using gdb with dotnet 6.0. Looks like incompatible elf format for executable, faulting on loading the application. FWIW. We are going to proceed with 5 until this is resolved.
Program received signal SIGSEGV, Segmentation fault.
0x76fdaa70 in relocate_pc24 (value=value@entry=1420468224, addend=25534592, map=0x76fff958)
at ā¦/sysdeps/arm/dl-machine.h:342
342 *reloc_addr = (*reloc_addr & 0xff000000) | ((new_value >> 2) & 0x00ffffff);
(gdb) bt #0 0x76fdaa70 in relocate_pc24 (value=value@entry=1420468224, addend=25534592,
map=0x76fff958) at ā¦/sysdeps/arm/dl-machine.h:342 #1 0x76fdba78 in elf_machine_rel (skip_ifunc=, reloc_addr_arg=0x54aac5bc,
version=, sym=0x54aaa234, reloc=0x54aaba44, map=0x76fff958)
at ā¦/sysdeps/arm/dl-machine.h:486 #2 elf_dynamic_do_Rel (skip_ifunc=, lazy=,
nrelative=, relsize=, reladdr=,
map=0x76fff958) at do-rel.h:137 #3 _dl_relocate_object (scope=, reloc_mode=,
consider_profiling=, consider_profiling@entry=0) at dl-reloc.c:258 #4 0x76fd2a50 in dl_main (phdr=, phnum=,
user_entry=, auxv=) at rtld.c:2075 #5 0x76fe6c24 in _dl_sysdep_start (start_argptr=start_argptr@entry=0x7efff730,
dl_main=0x76fd00fc <dl_main>) at ā¦/elf/dl-sysdep.c:249 #6 0x76fd3fcc in _dl_start_final (arg=0x7efff730) at rtld.c:309 #7 _dl_start (arg=0x7efff730) at rtld.c:415 #8 0x76fcfb10 in _start () from /lib/ld-linux-armhf.so.3
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
