Strategy not connecting to I/O Units
I’m having a very annoying problem with I/O units not connecting in the strategy, even when I try to enable the connection manually it doesn’t even holds the set timeout, it is just too quick and doesn’t connect. IP addresses are correct, I can ping them and even connect to the units with PAC Manager and no problems. I tried with the strategy downloaded to a physical SB1 and with PAC Sim and the behavior is the same. Has someone experienced something similar? Everything was working perfectly and suddenly this happened.
Please drop an email to support @ opto 22 They can start trouble shooting the problem with you.
