Hi Matt,
Welcome to the OptoForums.
[B]SHORT ANSWER:[/B]
Store the whole Archive (a zip file) created when you select File > Archive strategy (this is in PAC Control config mode). By design, it has all the files you need. We also strongly recommend you select File > Strategy options and check all three boxes there on the Archive tab, especially when you’re “done” with your latest changes. This will store the archive on the controller itself.
[B]MORE DETAIL THAN YOU MIGHT WANT:[/B]
As a recovering software engineer myself, I agree that the archive functionality is not the same. Putting a binary file under revision control means you can’t do a “diff” between versions, you’re just using the repository as a safe place to keep that file with some comments. If you’d like a text file to store with your zip, you can (again from PAC Control config mode) highlight your control engine in the strategy tree then select Compile > Compile Control Engine Download File.
The resulting .cdf file is text, but it’s your compiled strategy. As you may know, PAC Control compiles your strategy into Forth for interpreting by the control engine. So unless your software engineering experience happens to include loads of Forth programming, it’s a bit clunky to look at.
Before compiling this file, you might want to temporarily select Configure > Full Debug. Then the resulting file will have extra commands (or “words” as they’re called in Forth) like “5 LINE.NUM” to indicate line numbers. This way, when you’re doing a “diff” between one .cdf and another, you’ll have an easier time figuring out where in your strategy something changed between different versions of that .cdf.
[B]PAC DISPLAY?[/B]
You mentioned your strategy in particular. Do you also have a PAC Display project? If so, you’ll want to select File > Archive Project and keep that zip file in a safe place (or three) also.
Good question!
