.NET OptoMMP SDK
#1
Hi,
I’m working with the latest .NET OptoMMP SDK (R3.0.7.0), and have some questions regarding the API:
public int ReadHighDensityDigitalState(int i32PointNumber, out bool bState);
Why is there not a complimentary Write method?
public int ReadHighDensityDigitalState(int i32Module, int i32Point, out bool bState);
public int WriteHighDensityDigitalState(int i32Module, int i32Point, bool bState);
The second parameter, i32Point, is misnamed; a channel number is required, not a point number. In addition, both methods check whether the value of i32Point is within the range 0-63. Shouldn’t the maximum allowable value be 31?
Thank you
#2
Welcome to the forums!
I agree with you, there probably should be a WriteHighDensityDigitalState method and the i32Point should be named i32Channel to be consistent with other methods. Hopefully Opto can fix this on the next version.
If you study the memory map a bit, you will find that they left the opportunity for 64 channel modules. This is probably why the SDK allows this.
#3
Sometimes we use the names “point” and “channel” to mean the same thing (vs. a module). How do you use/interpret those? For the point/channel range, our high-density digital points currently support only 32 max, but we’ve left room for future expansion in there for up to 64.
What type of hardware are you using? SNAP-PAC-R or -EB?
I ask because, if you’re using a SNAP-PAC-R, you can skip the dlls and SDKs and just do an HTTP POST or GET to the RESTful API, which might simplify things in some cases, here’s an example w/an analog point:
http://developer.opto22.com/rest/pac/examples/read-a-point/
Looks like we have that Write method you expected in there:
If you’re still having trouble, don’t forget our support is free! (Best to reach them via email, support@opto22.com).
#4
The other methods (that I looked at anyways) in the SDK use the term “channel”
Yes, but the Read has an overload that can take just the 0-511 HDD point #, the Write method does not have this overload.
#5
You mean slot? :grin:
#6
Yes! And do we start counting with a 0 or a 1, let’s not get going on that! :smile:
#7
What happens when you can’t decide:
#8
Thank you both for your replies, i appreciate it.
I am working with a SNAP-PAC-EB2 Brain, so i must use the SDK. And that’s okay, it is not causing me problems. My intention was to point out some inconsistencies in the API, in the interest of improving it.
#9
Thank you for the feedback. The corresponding write method has been added to the toolkit in version R4.0a. It is available here:
https://www.opto22.com/support/resources-tools/downloads/pac-dev-optommp-dotnet
I hope this helps you out. Thanks again.
