Error: Pool is closed
guys,
We are getting Pool os closed error in node-red.
We are using node-red from “EPIC PR1”.
Flow is clear, I have deleted all nodes.
Please find attached backup of nodered also.
Thanks & Regards,
Aanandnode-red.project.zip (338 Bytes)
Try and delete the project through groov Manage.
You probably still have some configuration nodes - so not everything is deleted. Click on the hamburger menu and then select Configuration Nodes and see what is in there.
@philip (and knolleary) are correct, see the answers you got on the Node-RED forums.
Error : Pool is closed - General - Node-RED Forum
Error is resolved.
Thanks
