I am trying to run an interface tied into a CANbus line with established traffic. The module itself works fine, with no problems, and transmits 2 to 3 messages in a loop. However, if I connect it to the application, i get a second or so of messages, and then it stops transmitting. If I reboot the PAC, i get another second or so and then it stops again. I get a “warning” message -52. This is only when connected to the main network. If it is the only thing transmitting, it works fine. Its only when there are other CANbus messages on the line.
