Not officially, no, sorry.
What I’m about to describe might not work for you, and I make no guarantee it’ll work beyond groov R3.4.
Events have their definitions built out of a chunk of JSON, and there’s a REST-ish API for listing, creating, updating, and deleting them. If you’re comfortable editing a JSON file and using Curl or Postman or something to work against a REST API, you can create an event that has two of the tags you need in it and just edit a text file (e.g. copy and paste a line a lot, changing the table index) to add the rest.
Before you try this, please back up your project in case something goes wrong.
First, you’ll need the API key from an editor user. In Build mode, look in the Configure menu and select Accounts…, and grab the API key for your user.
(Your API keys will be of the longer, ugly variety. I’m a developer, I can cheat. )
Create your template event, and give it a name you’ll recognize. Then, using your HTTP client of choice (curl, Postman, or just open a new browser window), navigate to this URL:
https://your.groov.com/api/v0/events?api_key=your_api_key
It’ll spit out a blob of JSON at you, that unfortunately has all whitespace removed to cut down on how much bandwidth it uses. You can use something like jq or JSON Pretty Print to reformat it into something easier to work with. Look for your event name in there: there’ll be an id number right above it.
Using that id number, build up this URL that directly references your event:
https://your.groov.com/api/v0events/<id>?api_key=your_api_key
That’ll spit out the JSON for just your event. Pass it through a pretty printer, and it’ll look something like this:
"id": 2,
"name": "1 Minute Test",
"enabled": true,
"condition": {
"children": [
"type": "compare",
"comparator": ">",
"tag_id": 2,
"tag_index": 0,
"tag_count": 1,
"value": 100,
"hysteresis": 0,
"debounce_time": 60
"type": "or"
"sendEmailOnBegin": true,
"sendEmailOnEnd": true,
"beginEmail": {
"subject": "",
"body": ""
"endEmail": {
"subject": "",
"body": ""
"recipients": {
"users": [
1
"groups": [],
"everyone": false
"state": "INACTIVE",
"errors": []
Copy that into a plain text editor. (Not something that allows you to change text colors or anything. Plain text only.) The part you want to focus on is this:
"children": [
"type": "compare",
"comparator": ">",
"tag_id": 2,
"tag_index": 0,
"tag_count": 1,
"value": 100,
"hysteresis": 0,
"debounce_time": 60
You’ll need one of those stanzas for each of the table indices you want to read, separated by commas. Just change the tag_index
field as you paste new ones in. For example, if I wanted to scan indices 1, 2, and 3 of that tag, my children
section would look like this:
"children": [
"type": "compare",
"comparator": ">",
"tag_id": 2,
"tag_index": 1,
"tag_count": 1,
"value": 100,
"hysteresis": 0,
"debounce_time": 60
"type": "compare",
"comparator": ">",
"tag_id": 2,
"tag_index": 2,
"tag_count": 1,
"value": 100,
"hysteresis": 0,
"debounce_time": 60
"type": "compare",
"comparator": ">",
"tag_id": 2,
"tag_index": 3,
"tag_count": 1,
"value": 100,
"hysteresis": 0,
"debounce_time": 60
Note that a trailing comma after the last index stanza will probably cause groov to reject it as invalid JSON.
Now! We have to get that back into groov. To do that, we need to issue an HTTP POST request to the same URL we used to retrieve the event definition in the first place, with that JSON text as the request body. I use Curl for this sort of thing, so I’d save it to a file (name it event.json or something), and then run at a command line:
curl -k --data-binary @/path/to/event.json https://my.groov.com/api/v0/events/<id>?api_key=my_api_key
If it goes well, it’ll print out the definition you just sent it. If something goes wrong, it’ll print Unable to parse event json.
Assuming it worked, you should be able to pop into Build mode and check the event to make sure it’s all ok.
A few important notes:
- I’ll state again: don’t be surprised if you try and use this in a newer or older version of groov and it doesn’t work. This particular API will only work in groov 3.3 or 3.4. (It was under a different URL in earlier versions and didn’t support API keys.)
- We actually haven’t finished implementing event validation on this particular API in released versions of groov; we still use the older one that I’m not detailing here.
- It’s very easy if you’re not careful here to create an event that the editor can’t handle. The event execution engine’s more flexible than the editor is, and supports things like nested comparisons and whatnot.
- Don’t bother trying the
tag_count
field: it doesn’t do what it should. groov’s not built to scan tables efficiently.
